1.174 visninger
Lille tandhjul suzuki passer flere? {{forumTopicSubject}}
passer det foreste tandhjul ikke på flere suzukier? sagen er jeg skla have et 17tand 520 tandhjul på min TL`er hvor standart er 17tand 530,,,, kan det lade sig gøre jeg bare finde et andet til en anden suzuki eller hvordan?
Følger: 21 Følgere: 20 MC-er: 1 Emner: 16 Svar: 875
Men jeg tror ikke der er særlig mange der er "født" med 520 størrelse.
Det er dog sjældendt et problem at finde et 520 tandhjul til en så kendt model hvis man vælger et uoriginalt tandhjul.
jun 2006
Følger: 155 Følgere: 151 MC-er: 9 Emner: 237 Svar: 1.848
tak for svaret god weekend;)
feb 2005
Følger: 78 Følgere: 78 MC-er: 4 Emner: 96 Svar: 1.930
jun 2006
okt 2004
Følger: 5 Følgere: 4 MC-er: 3 Emner: 21 Svar: 168
Jeg ved ikke om gearing og 520 tandhjul/käder har väret diskurterret för herinde, men på flere udenlandske sider som: TL forum http://www.canyonchasers.net/shop/generic/chain.php snakker de altid om det: De fleste foretaler at geare op i störrelsen bagpå, istedet for ned foran. her uddrag af texten:
Gearing: While we are on the subject of chains, a very popular upgrade is to lower the gearing to make the bike quicker off the line at the cost of top speed. The quickest and easiest way to lower gearing is to buy a front sprocket with one less tooth. Simply replacing the front doesn't require a new chain and will cost about $14.00 to do. However, the disadvantages of doing this are pretty significant. First, if you are not replacing your chain at the same time, it will lengthen your wheelbase; that's not such a big deal. But the biggest problem with dropping a tooth in front is you put a lot more torque on your countershaft. Possibly resulting in a ruined seal or worse, a bent countershaft ($$$ expensive $$$). I know of more than one TLS/TLR out there that bent countershafts within 50 miles of dropping to a smaller front sprocket - so this is likely more of an issue with high-torque motors. So the likelihood of this happening depends on how dramatic the change is and the characteristics of the motor, but its good to be aware of this before making any decisions. We strongly feel that the best way to lower gearing is to add teeth to the rear sprocket. Depending on how dramatic of a change you want, you will probably need a new chain. Usually, you increase four teeth in the rear to equal dropping one tooth in the front (but that varies greatly depending on what your stock gearing is). By changing rear sprockets, you have more control. You can go up any number of teeth to get the result you want. I have typically only gone up one or two teeth in the rear to get the results I wanted. Plus, you are shortening your wheelbase. This is cool if you want to ride a track or a canyon
520 convertering: Another common upgrade you hear about is a 520 conversion. A 520 is a smaller, lighter chain. The advantage of this upgrade is you will have less rotating mass, less inertia, and therefore an internal dyno like a Dynojet will report a horsepower increase. It's the same reason a lot of people put lighter wheels on their bikes. However, you will need to go with aluminum sprockets, because they don't make 520 steel sprockets, and you will use up chains and sprockets about 30% faster. Plus, because they are a lot lighter, high horsepower engines can snap a cheap or worn 520 chain easily. Another disadvantage is that a 520 chain and sprockets can be as much as 50% more money than a conventional setup. The true advantage of a 520 conversion is the sponsored racer who gets a new chain before every race. Even the most proficient street rider gets very little benefit from this and will never notice any difference.
Håber du kan bruge det til noget?
Bo
mar 2006
Følger: 9 Følgere: 10 MC-er: 2 Emner: 67 Svar: 890
Jeg kunne i hvert fald bruge det til noget. Har selv gået og tænkt på at skifte til et større baghjul.
Vidste godt det var en dårlig ide med det forreste lille tandhjul, men rart at få uddybet pro's & con's
jun 2006
aug 2008
Følger: 9 Følgere: 8 MC-er: 1 Emner: 43 Svar: 219
